Dual carburetors on 250 I-6?
Raider L
Shreveport, LA
William
And here are some more. Is there something on this bar above I can click that will turn this photo? Or what else can i do?
This is headers for Ford 300's and others/
And for you guys with a HUDSON!!! And Pontiac pickups! Joke.
Here's that set for my slant. You can see I have it marked.
I have the price sheets for that came with this catalog, but you old guys like me who remember all this stuff when it came out new, the prices are so low, I don't like looking at it because some of this stuff makes me cry, looking at how high this stuff is today is ridiculous.
As an example look at the cost of a t-shirt!!
@WamboJambo,
What is a "lump port", kit? What is a "lump" in a six?
I'd like to know this as well. Is it adding something along the lines of these:
The wings (lumps?) can be seen here, all the iron-headed 60° Chevy V6's had them.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
The Chevy 6 (194,230,250,292) is a terrible flowing head (non-integral) on the intake side by design. It has only 4 intake ports, with boss' in the middle of 2 of them that the head bolts pass through. There are 'lump port' kits that look a lot like the floor of the V6 intake ports shown above that can be bolted in. The 2 bosses are also cut out at the same time and bolts moved to the floor of the intake ports, IIRC everything correctly.
I've the theorized integral head is probably a better head on paper, but it has durability problems. Since they never came on the 292 version, the engineers probably knew it had some compromises in the design as well.
Carb'ed Vortec 350
Partly correct @CorvairGeek ,three siamese intake ports for 1-2/3-4/5-6. Six exhaust ports, with 2-3 and 4-5 being siamese in the exhaust manifold. Only one bolt boss to remove in each intake port.
The guy the made the adapter plate for Aussie Speed intake sent me a cool photo of some cutaways of a head with lumps shown. But since they're not mine, I don't feel right posting them.
This shows the T6 Performance lump. It is a newer design, and has a higher ramp than the previous design. Instead of the intake charge hitting the bolt boss and the intake valves from the side, the bolt boss is removed, and the intake charge goes up and over the ramp, thus improving the velocity of the charge.
Here is one showing the combustion chambers and can see the intake and exhaust ports on top.
That is when I got the head last year.
Enlarged from 1.72/1.50 to 1.94/1.60. Still need to massage the ports.
JBswth
Vallejo, California
James
C25
292 cubic inches
I think you will have to try Aussie Speed Or Offenhauser . They both have a 4 barrel manifold and they have 2 - 4 adapters that will allow you to use a 2 barrel, maybe a Rochester 2GC, which should be perfect for your engine. Offenhauser also has linkage for their 4 barrel manifold, so you should be able to get it to work on a 2 barrel. Be aware though, that the Aussie Speed manifold has really big runners, which will require you to use your gearbox. It probably won't lug well.
JBswth
Vallejo, California
James
C25
292 cubic inches
I have a 292 with an Offenhauser dual single-barrels, and I am using a pair of Rochester B type 1 barrels for a 235 - a pair of carbs for a 292 might be too much for my stock-cammed engine with stock ports head, and that carb has to have a manifold-mounted automatic choke. I have headers - and I feel it works surprisingly well. I made throttle linkage from a setup for a step-van with this engine, I can't remember what the bell-crank I used is for, and had to use a gas pedal for a late 50s pickup, which meant I had to make a hole in the floor toe board, as the L bracket that the pedal press on had to go through the floor. I don't know if you want to do that much fabricating.
ExtraZ
