Driveshafts and Lifts
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
We've been doing it wrong all along...
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
with an 8" lift, wouldn't shimming or rewelding the axle's spring pads be a good idea? otherwise it'll have some pretty extreme driveline angles, right?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
hirschdalechevy
norcal
rich
k-30
My blazer has 9 inch , all suspension lift , built for street and off road use , so this is what I did.
lowered the t-case 1 inch
custom built driveshafts
front end not rolled up
rear end rolled up (perches)
sway bar removed
Rolling the front up make's your square drive like crap , (mine is flat , no shim) , i used all stock spicer parts , longest slip yoke I could get and had to grind out some spots in the double cardan for downward travel, (you would not need to do that on a street truck), and had to be longer as well.
The rear shaft is just longer , I had to play with different shims to get the angle right , to have no vibrations and no wheel hop. Your t-case angle and pinion angle should be the same with a u-joint shaft , (mine is not but works well) but that is hard to do with big lift so having a double cardan shaft made is the way to go if you dont want to mess with trying to figure out a sweet spot with shims but you may still have to play with it a bit to be perfect, (rolling diff up).
I am not a fan of slip yoke's in the t-case so I have nothing to say on that ,
You will also have to have a steering box brace kit , (big tire's kill frame's)
Crossover steering is the way to go , but if you dont go that route you will need the tallest steering arm you can find and a drop pittman arm as well. Then if your draglink is way off from flat you may need an s shaped , dropped draglink as well.
New 8 inch springs will come with shims on them but that will mess with your caster a bit , (i took mine off) , but they help driveline angle. Get your square all set up and dive it around without a front shaft until you get it to drive the way you want , (playing with shims) and then get a driveline made.
My blazer wheels hard and sails down the highway at 80mph like a dream
hirschdalechevy
norcal
rich
k-30
At what point do you need to fix the steering?
My girls truck has a 6inch on it and it drive's good , but I may put crossover on it anyway,(stronger and improves steering all around imo.) I would for sure go crossover on anything over 6 inch lift, (just me).
Her truck is really sweet , 78 silverado , roller motor.
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
sway bar removed
Nice truck!
Great build!
Good post!
jlyon1006
