Driver switch not working on passenger window.
Skippy969
NC
GMC
I have an 85 GMC K1500. I'm working on the power windows and have run into a problem. The drivers side switch works for the drivers side, but not the passenger side. The passenger side switch does work for the passenger window. I tried jumping pink to tan or pink to blue with white stripe on the drivers switch and the passenger window still didn't roll down.
gmbellew
Kansas city
glen
suburban 1500
troubleshooting
Skippy969
NC
GMC
Thanks,
I'll try the troubleshooting today, but another thing I noticed while looking around. The blue/white wire and the tan wire coming from the passenger switch have a tap wire coming off and going to ground. If they aren't grounded, the passenger switch doesn't work. I checked continuity from the driver door switch blue/white and tan wires to the same wires on the passenger switch and they have continuity.
gmbellew
Kansas city
glen
suburban 1500
Thanks,
maybe somebody has added relays or something to the system? extra trouble shooting steps in that case, I reckon.
Scott91370
Burleson, Tx
Scott
Sierra1500
I had this issue and need to post my fix in my thread.
On the wiring harness side of the plug I had a wire break off on both the driver's & passenger's sides. Sounds like you may have already rules it out though.
Skippy969
NC
GMC
Update. I replaced the drivers harness and switch and it fixed the problem.
Scott91370
Burleson, Tx
Scott
Sierra1500
Do you know for sure which piece it was that did the trick?
ExtraZ
