Ozie P
- Mar 6, 2018
- FL
- Ozie
- K10
In my 84 K10 SWB, it’s has about an 1.5” lower height to the driver side of the bed. It has a 6” Skyjacker Suspension lift on it but the shocks have definitely had their share of life. I made the assumption of it being spring sag in on the driver side so I swapped the rear springs out for some stock ones. However, nothing changed. Any ideas? I took several measurements from the frame to the ground and the entire length of the frame the driver side is lower. I need help ASAP.
