Drive shaft bolts (torque specs)
DonA
E. TN
Don
K-10
4.3 V-6
I have a 1986 K-10 short bed (4.3L V6).
What are the torque specs for
1) the rear drive shaft, U-joint to differential bolts (two 2 bolt retainers)
2) the front drive shaft, four bolts to transfer case
Thanks.
ali_c20
Austria
Alexander
C20, K5
Retainer strap bolts: 18 ft lbs, I found specs ranging from 15 - 20.
CV flange: Check the bolt grade, size and thread. Look up the torque specs.
You can use loctite on both.
DonA
E. TN
Don
K-10
4.3 V-6
10-4
Thanks.
ChuckN
Bellinham, WA
Chad
Just to clarify, blue loctite ?
1978btan
