Door lock relay
Camar068
10 yrs Air Force
I'll be upgrading the doors to all electric in the spring. I'm having a hard time finding the relay and prefer not to get a used one from a junkyard. The doors and harness are from a ~88 Suburban.
I found some info on another site that it appears to be a Standard Motor Products model RY547. Do you think one for a 82-92 Cadillac (RY58) will work? Ebay link below. The connections look the same.
Feel free to post vehicles you've used before in place of the original, and/or any more information.
I'm hoping the only difference is the mounting bracket.
https://autoplicity.com/3576635-standard-motor-products-ry547?gclid=CKPN0fGkndICFdgagQod9P4HOQ
https://www.ebay.com/itm/Fits-Buick...913091?hash=item3b50c14203:g:sWUAAOSwRVReiFhf
Holy crap those things are expensive!
Craig 85
Nashville, TN
454/TH-400/NP205
That's because it's an original GM part. Anything in their catalog that starts with "G" is an NOS part.
Why wouldn't you just use a standard $5, 5-pin bosch style relay? This is retrofitting power door locks into a factory manual lock truck, right?
Yeah, but a lot of stuff has been available straight from GM for very good prices. That relay price caught me off guard.
fast68chevy
I am the original fast68chevy
LINCOLN IL
RANDY
just need a basic 4 or 5 pin relay. dirt heap and easy simple. the stock lock relay is under dash. could be on top of column and pedals support behind the cluster like in the vans etc.
hartgreen
Hart
G3500
Did you ever figure out if the RY58 would work? Im having the same issue.
Terry Wilkerson
Kansas
Terry
GMC 1500
Does each door lock have its own relay or are the both operated by one relay. Passenger side on my truck works driver side doesn't.
Terry Wilkerson
Kansas
Terry
GMC 1500
I found a wiring diagram of the door lock. I answered my own question.
Camar068
10 yrs Air Force
I ended up getting a 20167608 relay. I haven't installed it in the truck yet, but I havent converted to electric doors yet either. So I have the complete harness out of the truck. It runs off 3 wires. I have tested it and it works fine for me. If you look up RY58 on Amazon you'll see exactly what I have....including the 20167608 part# on it in the 2nd pic. $65 on Amazon.
RY58 Amazon
RatDawg
