scrap--metal
- Sep 15, 2021
- MN
- Calvin
- '85, '81
- K10, K20
That's ridiculous! Even on a truck in rough shape like mine, I would never do something that silly.The '82-'96 GM A-body platform also had door hinges with one bolt from the inside. I don't know the reason for such a design, but you should read the hinge replacement procedure in the A-body factory service manual, lol. For the front door, upper hinges, you must remove the dash to properly (imho) change them. But the service manual says to use a hole saw and then let the bolt fall down inside the pillar... then pump in a bunch of caulking to keep the bolt from rattling
Before I work up the courage (and time) to tackle this door hinge project, I'm wondering if I can get at that interior hinge bolt by just removing the bezel and the left most AC vent? Does the gauge cluster have to come out as well? Or do I need to pull even more than that out to get at it?
The truck I got the replacement door off of was already pretty dismembered.
