87ChevyR10
- Sep 2, 2013
- Kansas
- John
- NA
- NA
- NA
How tough are they to replace? And how do I replace them?
Thx
Thx
They`re not too bad. if You do`nt have help and there`s wires from door to cab, use a floor crane/cherry picker to hold the door while working on it. a strap around the top window frame and let it hang there while You are removing the old bushings and cleaning things up. be sure to put some good grease, like assembly lube in the new bushings and on the new pins too.
you should be replacing the spring while you are replacing the pins and bushings, they are only $5.....
Is the spring fairly easy to replace with the pins out? My drivers door is missing the spring and if it's easier to replace with the pins out, that would be a good excuse to do it all at once.
The ribbed bushings are used if the hing holes are out of round and need to be drilled to make them round again. In all the ones I have done using the HELP brand kits, the pin never seats all the way back down like the OEM ones. I did just like you, drive them down until they stop.
