Door hinge pin
mavtricks71
az
mike
So I have to do my Door hinge pins on drivers side, the kit comes with 2 splined bushing and 2 normal brass bushings. Do the splined bushing press right into the hole or am I going to need to drill out the hinge, Anybody whos done this before please chime in.... Thanks so much Mike
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
They usually tap in unless the holes are oblong then they fall in.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Ok cool thanks ...as soon as I get my parts the fun will start
Oh yeah lol could be worse these doors aren’t that heavy. I think the worse ones I ever did were on one of my Monzas.
mavtricks71
az
mike
Heaviest longest door I did was a 2 door Ford maverick....small car but the doors are long and heavy
Crispy
Carbon County, Pennsyltucky
Suburban V1500
I have to do this as well come spring time. I'm glad its the burb and not my 79 Trans Am.
Let us know how it goes, I'm definitely curious to see what I'm getting into.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
They aren’t to bad.... if your truck is lifted putting a jack under the door could be a bitch lol
Crispy
Suburban V1500
Nothing a bunch of 4x4 pieces of wood cant help, but I'm stock height, probably sagging a bit. ...and another thing to add to the list.
SkinnyG
Canada, eh?!
G
C10 Silverado
350/TH350
When I did mine, I used the smooth brass bushings because they slipped right into the holes. I think the thicker, (corrugated?) bushing might be for when the hole is REALLY worn out, and you drill it oversize to fit. But I might be wrong - I never found the answer on that one either.
SDJunkMan
Black Hills of South Dakota
Jeff
The pins in my doors are getting a little loose, can they be replaced without taking the doors off the truck, or do I have to take the doors off? Need to replace the striker bolts too, they are worn down pretty bad (and not just the plastic).
74 Shortbed
No need to take the door off just support it, pretty easy with two sets of hands..
350 w/203
Try a '73 Firebird door sometime.
jlyon1006
