Does lowering effect load carrying ability?
quadracerx
Graham, WA. USA
Steve
Im in the process of lowering my 1988 GMC (its the square cab body style) using a 3/4 Beltech kit. I am also thinking about buying a slide in self contained camper...
Will lowering effect my ability to carry the camper, it will be a 10-12 foot slide in type...
Thanks,
Steve
Big Chip
Michigan
Kevin
C35
Thanks,
Steve
I would suggest helper bags with a big camper in there.
quadracerx
Graham, WA. USA
Steve
My truck also has a "Hidden" 5th Wheel Hitch" there is a crank hidden in the wheelwell to raise it up...
Will this effect the installation of the Beltech lowering kit?
I planned on air bags if I do the camper but thanks for the reminder....
Steve
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
If your spring rate stays the same, lowering it will actually improve it’s center of gravity—albeit, not much. Those big campers are probably harder on suspension than anything else.
Big Chip
Michigan
Kevin
C35
Do you mean a gooseneck hitch? I’m not sure how that would work since the plate is usually right over the differential or maybe slightly forward of the axle centerline.
Big Chip
Michigan
Kevin
C35
Take a picture of the hitch and post it here.
Snoots
Roger
Jimmy Sierra
350 w/203
Redneck Station Wagon.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Someone should have told this guy.
Damn, that is a big slide in.
What is that at the bottom of the front passenger door?
Big Chip
Michigan
Kevin
C35
I couldn’t tell you.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
It's a step that sides in and out. My recollection is that it attaches to the bottom of the door. These were popular before running boards.
varmit86
Washington
Mark
C30
To go down 4 in the rear should not be a problem, I pretty sure Bell tech uses the shackle, hanger and C notch but you also remove the overload perches and springs that is where your problem is going to be. Some good sized air helper spring will do the trick for you. also would recommend aftermarket heavy duty sway bar in the rear, that big camper is a huge wind brake.
If you wanted more you should check out my project for sale it has a full four link rear air suspension would solve all your problems.
Trucktruxktrukk
