- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Me too, as soon as I seen it.Yeah, I was starting to have flashbacks
I like it. Looks good MisterB! ! Yours looks nicer than mine in that it is centered. Apparently, my transfer case is fulltime and is offset to the right. So I had to offset my cutout to the right. Enjoy your coffee now on the way to work.Hey, I think this is gonna work!You must be registered for see images attach
Sent from my SM-N975U1 using Tapatalk
My T case is off set to the right as well, but it looked like it might interfere with the handle of my fire extinguisher if I moved it to the left. It also seemed like it would look a little better being centered on the knob, not to mention in line with the CB radio, and it gives me plenty of room for my leg.I like it. Looks good MisterB! ! Yours looks nicer than mine in that it is centered. Apparently, my transfer case is fulltime and is offset to the right. So I had to offset my cutout to the right. Enjoy your coffee now on the way to work.
I have no shortage of jumper cable and gas cans from impound cars. I usually carry spares to give away. I hate seeing someone out of gas and 7-11 or a gas station wants to sell them a can for $20 so I give them a can or someone who needs a jump and let them keep the cables since chances are they may need them again before they get a battery replaced. Doing my thang to help the poor and here I stay poor.
Man that looks good! I just found this thread again.Well, I ordered it, thanks to 80BrownK10, and got it and modified it. I like it.You must be registered for see images attach
Sent from my SM-G960U using Tapatalk
Looks good. Did you buy the same one?Hey, I think this is gonna work!You must be registered for see images attach
Yes, same one. The screw you see is just the metal ring that goes around the rubber bootLooks good. Did you buy the same one?
Is that a screw in the very bottom below the shifter..in that small cupped area?
What size yeti tumbler is that?Yes, same one. The screw you see is just the metal ring that goes around the rubber boot
Too bad that won’t work with a floor shift manual. That’s a really neat looking way to do it.Do you think someone cut a hole in that one for shifter and set it there over it?
It's a 20 oz. Doesn't fit perfect, but doable. I have another Wylde Gear tumbler that fits a little better, since it's a tad more narrow at the bottom.What size yeti tumbler is that?
I know, I checked it out again, and said Damn! Look how cheap it is now. I should buy a couple more. . .I just checked that cupholder. It's down to $7.40. it was $13 when I posted the link. I am going to order it now and just stick it in the shed till I decide to get after the mod. That's cheap enough. $13 wasn't bad but this is a great price for cupholders for our square.
