Do intermittent wipers use a different wiper motor?
t44e6
NH USA
I have an 82 K10 Custom Deluxe with 2 speed wipers, and would like the intermittent feature. I have replaced the wiper motor with a rebuilt unit that was identical to the original. Is the intermittent function in the switch, and is the motor the same? I currently have my dash pad and instrument panel cover panel removed and if it's a matter of replacing the switch I'd like to do it. The aftermarket modules I see go to 1977. Was it even available?
SirRobyn0
Rob
As far as I know Dave is correct, but I'm also going to draw @Doppleganger Chris in because I know he knows these wiper motors inside and out.
I will also add that the intermittent modules are not very reliable and prone to failure. You will need an intermittent switch as well. What I would suggest is getting one of those standalone wiper delay boxes available aftermarket so long as you don't mind it not being factory. I can provide you links to those if you want.
BadBowtie
North Texas
Jon
Chevrolet
5.0L
Correct. Just plug in play. Get a junkyard or new delay wiper dash switch and the pulse/delay module.
It all plugs inline together with your current underdash harness.
fast 99
Spokane, Washington
Do you know who has new modules? Can find them listed in several places but are discontinued and/or out of stock. Used are no good, have several, all bad.
90Burb316
Jeff
V2500
You can get them from LMC
tadslc
Birmingham, AL
Tad
350 Blueprint
That link shows it fits 73-77 year trucks
