DIY Bedliner
Derrick
near Milwaukee, Wisconsin
Derrick
I am planning on doing Bedliner in my 03. It has to be the same concept as these squares. so what is the best DIY spray/roll on bed liner leave links if possible?
1 needs to protect the bed and not peel
2 needs to stay black and not turn light black
3 want to stay under $150
Dougnsalem
Pick whatever color you want.
yevgenievich
Place
Name
Year
Model
Size
I did herculiner sprayed with a borrowed gun. It was great at first, but easy to brake. I should have sprayed it thicker, being the truck was black I did not judge the coating thickness very well. It did not fade too bad while I owned it.
Dougnsalem
Whoops. My bad. I now see you wanted it in black. This is a great deal....
Derrick
Derrick
like talking to window lickers, no crayons will not stand up to what i need it i think you need to stop eating them. thanks @yevgenievich i will look into Herculiner.
Battlac40
New Mexico
James
K1500 Sierra Classic
Raptor liner is tintable from the paint counter ( for a richer color ); has a shiny flake in it too. Lays down pretty flat with a roller. Texture is thinner than line-x but more aggressive and alot cheaper.
Derrick
Derrick
I will have to look into it thanks.
smurfasaur
Central WA
Austin
I haven’t used either personally, but I go back and forth between raptor liner and monstaliner.
I think I the end I’m going to get some monstaliner for my bed, bumper, and rockers. It has a huge following online and seems to hold up amazing over time. Couple that with the ease of rolling it on and it seems to be hard to beat. It’s also comes in like 40 colors if you want to go crazy with that stuff too
86Peter454
Missouri
C10 Scottsdale
ive read good things about raptor and its generally on the cheaper side.
my dad has used it on a few customer cars as well and he seems to like it.
Battlac40
New Mexico
James
Don't like the result of hurculiner.
Hard, plasticy, heavy, thick-course spatter that looks like it should be on households . . instead of a 40yr old trucks.
Ruins the gun too.
:beatdeadhorse5:
iandrake
