Disk brake conversion
That's alot cheaper than Mico systems and if it works, it works.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i used square body 3/4 ton front rotors and calipers i bought new ones from orieliy auto parts for a 86chevy 3/4 ton
and as far as the dana 70 yes dually trucks did come with the dana 70 but not all duallies did
cab and chassis used a narrow 14 bolt
if it was a pick up with a normal bed from the factory it had a dana 70 witch was wider than any other rear axle
this is just what i have run into not sure its 100 percent true
TexasOutlaw87Cummins
santee
cody
k 30
5.9 cummins
Any hope for us having rear disc brakes then ? I was looming the other day said 70 next to the pinion so just figured it was a 70
chevyzz8
Wisconsin
c30
Will this clear cab and chaasis rear? duals and leafs so close on mine maybe enough space for a finger
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
I know this thread is a bit old, but I'd like to update with the fact that diy4x has a Dana 70 dually disc conversion kit:
http://diy4x.com/cart/index.php?route=product/product&path=37&product_id=149
It says all you need is a set of 3/4 ton rotors/calipers (no e-brake though), and then a disc/disc prop valve or master. My only question to those who have done rear discs, did you use an aftermarket prop valve or a later-model master? Did you have hydroboost if you used a different master?
nvrenuf
Mobile, Al.
I have vac brakes and used a master cylinder off of a '99 C3500 (factory 1 ton, vac assist 4whl disc application).
77 K20
Montana
K20 5" lift
HT383 fuel injected
Sorry for the dumb questions- but don't know a whole lot about the brake system. So if you put disc brakes on the rear and you install a master cylinder off of a newer truck then you do not need the special proportional valve?
And what is the vac assist for?
da_raabi
FloriDUH
Adam
c30
Pretty sure it eliminates the prop valve.
Heres another question: will a vacuum master work on a hydroboost truck? I have hydroboost and I was looking at using a vacuum master on it...
Also, which 3/4 ton brakes do I need? Rockauto has both 13" and 11" rotors, which should I get?
EDIT: I was wrong on the rotors, they are ALL 12.5" rotors, but for some reason there are options for 11" rotor calipers, not sure whats up with that but oh well. Also, from what I can see a master cylinder off of a vacuum boost truck should work with hydroboost, but the bore on the '99 master mentioned above is only 1 1/4" while the one listed for the C30 is a 1 5/16". Will this be a problem, or is 1/16" not a big deal in the master cylinder bore?
John-e Bravada
Oregon IL
C30 3+3
5.9L CTD
Did you ever figure out what to run for a hydro rear disc setup? Mine has a rock hard and not very powerful pedal. I'm thinking of running a smaller master for more pedal throw and power. I developed a leak and have to bleed it so there's no time like the present to swap master.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Do you know what size bore your master has now? Running a smaller bore does indeed make more pressure and will give you a softer pedal feel, but will require the pedal to move to the floor more. If you go too small it can make the pedal sink all the way to the floor and you won't stop either.
John-e Bravada
Oregon IL
C30 3+3
5.9L CTD
I'm not sure, stock 86' C30 454 hydroboost size :) I didn't measure it when I swapped hydroboost units. I should have...
77 K20
Montana
K20 5" lift
HT383 fuel injected
So far by looking around online it looks like 1.312" is the stock size bore for a '86 C30.
Spork
