Dirt Trail K10 Question
mitch_f
Virginia
Mitch
350 V8
(I’m quite new to this forum, and square body’s in general, so let me know if I’m doing anything wrong) I have an 86 Chevy K10, 2dr, long bed, that I hope to make a fun, daily-able truck than I can rip around some tight forest dirt trails, but is currently just a normal, rusty, k10. How should I upgrade it to handle these tasks?
JeffK10America
Easley sc
Jeff
A can of WD40 some duck tape , vise grips any man with any salt can tackle anything with just these things .lol
Nah man just messing with ye !
Put some tires , shocks good brakes maybe a lift . And your engine purring ! Go have fun on those trails .
83Burban
Kansas CIty, MO
Matthew
Suburban K10
@mitch_f.
Assuming it starts, runs, and stops well....
I would rebuild your front end (ball joints / tie rods / drag links) ...or at least be prepared to. In the process of installing all moog parts now. Got hung up because the previous owner swapped the axle with a D44 out of a 75ish something. So half of my rebuild kit is no good to me
So...really....the most important part before you start buying parts and making modifications is.....verify your equipment. Learn from my mistakes. ID your axles / hubs / motor / trans / t-case.....ect ect. Save yourself the time, stress, and heart ache.
Raider L
Shreveport, LA
William
@mitch_f,
Welcome to the forum from Louisiana!
What engine do you have? Is it a stick or auto? What tires do you presently have on it? What kind of shape are the shocks in? Steering? What do the sway bar bushings look like, split, cracked, missing? Do you have a rear sway bar? Get one. How much lift does it have? What kind of shape are the universal joints in? When was the last time you changed differential fluid, gear box fluid or transmission fluid, filter? Do you have a oil cooler, transmission cooler, power steering fluid cooler? Get them.
This should give you some idea what you are going to need to keep up with if you plan on off roading. Maintenence is key to having this fun, tight ripping I know you want to enjoy. Also, do you have a winch? Get one because if you are out in the "forest" and it's been raining you will get stuck. It ain't all fun and games. There's broke stuff and work to get your a** out of the "forest" and night is coming!
mitch_f
Virginia
Mitch
350 V8
Thank you guys for the reply’s, they’re very helpful
83Burban
Kansas CIty, MO
Matthew
Suburban K10
If you get stumped on something....dont hesitate to reach out. This place is a wealth of knowledge.
What do you have going on under the hood?
mitch_f
Virginia
Mitch
350 V8
350, completely stock to my knowledge
scrap--metal
MN
Calvin
'85, '81
K10, K20
Make sure you have a good set of tires. Especially if you plan to daily and off road it.
Most "normal, rusty, k10" s that I've seen do not come with good tires. At least the ones that I've bought never did.
MTsquare
