dexron VI in a th350?
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
i got two cases of this stuff laying around is it okay to use in a th350 or should i used normal dexmerc III?
74 Shortbed
Both are Dextron so they're compatible, if it's a fresh/dry tranny then I agree Type F for sure..
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Yes it can be mixed I was thinking it was the synthetic stuff but it isn't. I like Type F no granny shifting going on here lol.
jake wells
Can i be me?
jake
custom deluxe 10
type F is for ford C6 transmissions
and this is not a fresh tranny.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Type F is pretty much the same as B&M Trick shift just way cheaper. It gives firmer shift and in doing that it saves clutch pack life and reduces heat build up. Dextron promotes clutch slippage which causes heat but does give you a smoother shift. Lincoln uses Dexrton in their trannys for a smoother shift.
74 Shortbed
Dextron also has an anti-foaming agent in it, and is not compatible with Type F.
jake wells
Can i be me?
jake
custom deluxe 10
only thing i was going to do was drain the pan and replace the fluid and filter
jake wells
Can i be me?
jake
custom deluxe 10
i plan on changing the filter and fluid then try to get out most of the old fluid by running one of the cooler lines into a bucket.
drain 4qt add 4qts etc....
74 Shortbed
A little expensive but that works..
jake wells
Can i be me?
jake
custom deluxe 10
i got 28 quarts so that should be enough to flush out the old stuff.
the trans is a rebuilt unit for oreilly auto and has a little over 20,000 on it the fluid is clear but it has started to darken.
74 Shortbed
Yep, that should do it..
TJONES360
