- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
I am trying to weigh between getting associated tools to crimp and make pins/tools to insert them into connector bodies/remove and do the associated learning of how to do that or replacing any bad connectors with splice in units.
I have pretty much done the math.... a vehicle harness with unknown age/brittleness or god forbid a new one with THAT many connectors is still more than buying a crap load of new connector ends to splice... but problem is, fuel injected kinda modern car... this would add a lot of bulk and runs in the wire that wouldnt be very routable without really rethinking a lot of things.... and just the labor aspect.
But... my problem isnt broken connector bodies, i have a lot of in-insulation wiring breaks AT the connector seals(harsh angles and pinched, etc) and issues with bad contact into those slots because most connector wires were pulled hard and to one direction making stress points.. so that is why I ask about repair, if the tools arent bad or many and i have the time, I can remove damaged sections and repin them and most wont even need more wire, just have to route it better than the last guy. From a quick google search, a a couple tools that seem to be about 20$ and a kit with bodies, pins, seals etc may set me back close to 150 maybe more.. but that is beating both a harness and new connectors. and i could probably get away with auto-store bins for any spot-needs of bodies/seals and just buy contacts/pins.
a lot of the inquestion connectors are peppered close to eachother and are numerous straight across the top of the engine for most part, and seeing someone do a splice repair on just a 3 connector sub-harness on a forum which is at most 14 gauge really impeded the ability to route it witout making more problem points and making the once conduit wrapped thing look like a burrito of pvc and vinyl and copper lol
i can show my situation if needed but im sure i visualized it more-than-necessary enough..
by chance, do these questions that im asking for weatherpack/multipack etc work for older
"packard" ones like on our squares or do they need diff tools/pins? I dont need to redo much for the square but if i can justify the purchase because of future-use on more cars that would help i think
I know someone here helped me last time with an electrical diagram question and seems to be a guru but I cant find that thread lol. I feel like it was either reckless raider or craig but if that isnt even close then good thing im making a thread lmao
