87chevy_com
- May 7, 2023
- Texas
- Clint
- R10
- L83
first post here, (i see this thread is a year old too)
I am usually on 67-72truckforums. I too have been wanting pulse wipers to work on my 1987 (factory pulse optioned truck) for years. I don't drive it much in the rain, but when I do, delay is quite nice... it quit working years ago. I came across detroit muscle wiper module solution, and found that they use a modern wiper motor, 2015 corvette, their harness, their module and their adapter bracket ... I want ready to spend that much, being that I am extremely crafty when it comes to fabrication and wiring.
There's several things I don't like about their solution:
its not for 84+ with column wiper switch
doesn't use factory wiring which requires an additional hole in the firewall
Anyway, I decided to buy a wiper motor from rockauto. Found the part number for the wiper motor conector and gm wants over 100$ for a pigtail lol... did some research, got the connector, terminals and seals for around 20$... Prefer no mumbo jumbo splices when its not necessary... anyway.. bought an ArduinoUno years ago to play with, barly now how to use it, so learned a lot and got myself a working wiper delay program.
Once I got the program to work, I bought a GMT400 style wiper switch, looks identical to the stock c-10 but only has 3 wires and has the modern detents between the 5 delay speeds (which is why I bought it in the first place. Did more debugging, more programming and got it to work with the corvette wiper motor... (wired like OEM)
Now that I had 2 working programs, with both switch's, I figured why not use the factory wiper motor? And then made the "relay harness" work with the factory wiper!
And then learned how to use another program, Eagle so I can make a PCB... about 2 weeks later, 2nd version:
designed so the module goes off to one side under dash, the relay module goes off to the other side, and the connections are OE on the column with no bulk...
video link hosted on my website:
gmt400 Switch, c-10 wiper motor test
link my thread on the project on the other forum
87 c-10 r-10 pulse wiper options - The 1947 - Present Chevrolet & GMC Truck Message Board Network
87 c-10 r-10 pulse wiper options The 1973 - 1987 Chevrolet & GMC Squarebody Pickups Message Board
67-72chevytrucks.com
