Not exactly sure how to use the meter to do that but I'll figure it out....or maybe even read the instructions
Would it tell me anything if I disconnected the module on the motor side and applied the probes to the module itself?
Nah, that won't work - don't even bother. That's because there is no variable resistance to even measure on the load (motor) side of the module. The sole purpose of the variable resistance - that which is created by twisting the knob (and rotating the guts of the switch) - is to send a signal to the module indicating what sweep rate the operator wants. The module can "understand" that change in resistance and uses it to generate a pulsed path to ground on the GRY 91. Basically, it receives an analog signal and converts that into a digital output.
The point is, the variable resistance signal goes into the module and that is it - it ends there. It doesn't have anything to do with the other side. The two BRN 96 leads don't even pass through the module. That is why there are seven (7) leads coming into the module from the switch and only five (5) going out to the motor. As we discussed, everything after the switch/module is the same - whether the system is pulse or non-pulse.
On this:
Started the engine and set the delay to "slow"
Applied probes and measured .2
Turned stalk to delay "fast" and measured .4
Took second reading after about 3 minutes and the readings went up to .4 and .6 respectively
The meter measured out to thousandths but the above figures were rounded down
I guess I need to know what the resistance needs to be. I have no idea where I'd find that.
Do you think this indicates that my switch harness is ok?
IDK for sure, but I would say that, yes. It would appear that you have proven proper operation of the variable resistor and the wiring to the module. I don't believe we will ever be able to find the actual range of resistance - by looking on the internet or in manuals. I guess GM believes that some things are simply not meant to be known by mortal man.
The best way to get that info would be for me to get off my lazy ass, go down to my nearly gutted truck and get some ohm values from slow to fast sweep rate. I know that my switch is good (I am starting to doubt myself on whether I sent you a good module). Bear with me for a couple of days and I will come up with that info for you. My truck is only about 15 minutes away - waiting to have the frame sandblasted - and I have to see the blast guy anyway.
The operation of the GM pulse wiper system isn't widely understood. But I'll tell you one thing; when we are done with this project, you will know as much as anyone about how it works.
BTW - this is not a normal circuit, so what you did worked this time. But for future reference, you should never try to measure resistance in a live circuit. Not that you will get hurt or damage anything, but doing it that way will oftentimes result in skewed readings. When measuring resistance across a component, it should be de-energized and removed from the circuit.
