Dash controls for delay wipers?
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
During my LS swap I'm wanting to go to an aftermarket steering column and move my wiper controls to the dash. I'm looking for a decent switch that I can make work and I'm not coming up with much. It's a delay-hi-low motor. Does anybody know of anything good that I could wire in?
The best thing I've found so far is a switch for a 78-83 C10 with delay and a 3 speed. I think it might work, but I'm not sure. https://www.classicmuscle.com/78175...R7cMBMEQV_8lKLjYEZjPoP6OThPwcNhoCEDgQAvD_BwE#
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I have a complete delay wiper setup I removed from my 81 GMC. I installed a later column for cruise control. It a remanufactured motor, probably 5 years old. 40 bucks plus the ride fair enough?
hatzie
k20
You need that switch and a delay module.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Got any pictures?
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Is there any particular reason the module I have won't work? Short of making the wiring match the new switch, what's different?
hatzie
k20
You can probably wire the 78-83 switch to mate with the later delay module but I don't know what kind of response it'll give you.
The 84-91 switch has two wires creating a loop from the controller through the delay stepped resistance circuit then wires for ground, hi, lo, and off.
The 78-83 switch is similar with the addition of the instrument panel lamp wire. The delay function is controlled by a potentiometer.
You'll have to lay the CD4 option wiring diagrams side by side and build a pigtail to mate the 78-83 switch with the later model delay module.
You'll also need to mate the earlier cab harness with the 84 up delay module.
The lists of GM circuit number functions in the front of the 1984 and 1979 wiring diagrams are extremely helpful.
350 w/203
Is that the type that has the wiper control on the stalk?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
No, on the dash. I have the switch, delay module, and motor.
Big Chip
Michigan
Kevin
C35
If the OP doesn’t want it I’d buy it from you.
350 w/203
HEY! My 40 bucks is in the mail! ;-)
This is WAR!
I'll give you $50 + ride fare.
Just yankin' yer chain Big Chip. I would buy it but you beat me to it.
78C10BigTen
pennsylvannia
C10 BIG TEN
I have both of those... lol
350 w/203
Please could you post a pic of the motor?
jlyon1006
