dana60 calipers ford gm
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
Do the twin piston calipers from the ford 60 fit on the gm 60. With out changing the bracket and do they stop better. Any thoughts on it anyone done it
nvrenuf
Mobile, Al.
No, they do not fit. The Ford calipers are longer from top to bottom than a GM/Dodge caliper.
Also the brackets do not interchange as Ford's are 5 bolt whereas GM & Dodge are 6 bolt. To use a Ford caliper you'd have to swap everything from the knuckle out.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Ok thanks..... man there is a wealth of knowledge on here just to bounce things off of eachother and find answers to things ive never even thought of
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
What about the ford dana 50 front hubs? will they fit on a dana 60? I have a couple sets of single wheel ones I've saved thinking they might work to converet a dually over
nvrenuf
Mobile, Al.
All Ford stuff is 5/8" shorter (stub, spindle and bearing hub) than Chevy & Dodge so you'd still need to swap everything from the knuckles out.
That said, the TTB D50 bearing hubs will work on a king pin Ford D60. All of the other TTB parts are different from similar Ford D60 parts.
jmacc
