K10blueChevy
- Mar 2, 2017
- VA
- Tom
- K10
First let me say if this is covered else where point me to it.
I'm new to the inner workings of these front axles on these square bodies.
I have an 83 K10 that has bad ball joints. I assumed swapping in a good working axle would be the easier job. Purchased said working axle only to find out I purchased a turd. The purchased axle is a Dana 44 out of a 72 K5 Blazer. After replacing the spider gears and all the seals in the hubs/spindles I realized the drivers side wasn't matching up.
The Dana has a late model axle and stub shaft on the drivers side. I noticed the late model axle has a larger ujoint and the stub shaft is machined differently. Which was causing the fitment issues with the spindle.
My question is should I finish what was started and upgrade the 44 to late model axles? If I go this route what all do I need to find? Is a set of late model spindles all I will need to swap or were the size of the wheel bearings changed and I will need to get the wheel hubs also?
Thanks for any help provided.
