Dakota Digital RTX Install Critique
tadslc
Birmingham, AL
Tad
350 Blueprint
Just installed a Dakota Digital RTX instrument cluster in my '81 C10 and wanted to throw out a couple opinions and comments.
I picked the RTX version because it mimics my stock instrument look almost exactly when off.
The first is that DD has it together when it comes to building and packaging this unit for our trucks. Right out of the box it is a complete kit. Everything is top notch. This is no Chinese junk I've become accustom to with a lot of aftermarket parts.
The second is read the instructions. I know that not everyone holds the same opinion but I bet I went over the instructions a dozen times before starting the install. It made it much easier for me.
Third is research the BIM modules offered by DD, options that could potentially make your install easier. I found one that helps integrate the Holley Sniper into the system and negates the installation of another temp gauge sensor and tachometer hook up by taking this information directly from the Sniper software. Won't stop the usage of the little 3.5" Sniper handheld but I found it quite helpful.
Fourth is there are several aftermarket pieces that made installation easier, at least for me.
The first is a New Vintage USA Adapter for the main instrument cluster wiring harness that does away with cutting any wires.
The second is a mounting bracket from Pro Performance that made installing the DD control unit and BIM much more professional looking. If you end up using more than 1 BIM you might have to do some creative installation but it's a great idea nonetheless.
Once installed I'm still finding it incredible the amount of information now available through this RTX system. Want to know your 0-60 times, 1/8 mile or 1/4 miles times? It's available. Want any alerts for low oil pressure, high coolant temps, etc.? It's available and you can customize anyway you want.
I could go on but you get the picture..
DD also offers a cruise control system which I have purchased but not installed. Much of the wiring can be hooked into the DD dash control module to help make this install easier as well.
Overall the install was not cheap but I think well worth the price. I rate it a 9.5 out of 10, maybe higher.
SquareRoot
Yup. Been enjoying mine for several years now. I use it with Edelbrock PF-4 efi and the amount of data displayed is amazing. I love being able to custom calibrate my fuel tanks to the EXACT amount of fuel in them, recalibrating the speedo after gear changes, low fuel alerts, engine hours.....blah blah blah.
kkgp81
Kelley
The DD clusters are good. I’m in the middle of one using the DD setup, 4L60e trans controller and American Autowire harness.
One thing to watch out for- do not install the temp or oil sender near your headers. It will melt out the plastic in the plug in. IE the factory water sender location or the oil filter plug in area.
1STLS1
West Phoenix AZ
MIchael
This was great information, thank you for the write up. I want one but waiting until I get to the point where I need it for the next step.
Dleslie212
Phoenix
Dustin
5.7L 350
That's cool about the bracket. I didn't know they existed. Howbmanynmodules fit on there? I have four - the DD module, the GPS module, the ProFlo 4 module and the gear indicator module. Would all of these fit on that bracket?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I am also not an instructions guy. But the ones included were very informational and easy to follow if you're savvy, don't need to be a wiring guru either!
Yeah I've had my Squarebody Syndicate versions for 3 years and nearly 40k miles now, these are by far the best gauges on the market. That bracket and the wiring adapter didn't exist when I did mine though, wish they had!
tadslc
Birmingham, AL
Tad
350 Blueprint
My bracket held the controller and 1 BIM. I didn't look into any other options, might want to ask them.
dr_diesel
Oklahoma City
Daniel
Thanks for all the info working on an 82 C20 and think I might go with the VHX model as it is a straight six with 3 speed. Just little touches here and there the kids and I are throwing in.
Silver Square
Fayetteville, GA
Jason
Sierra Grande 15
Thank you for this write-up. I ordered those 2 parts, was not looking forward to cutting and spling all that stuff lol. Was your fuel gauge crooked on your RTX gague cluster? Mine is offset noticably to the left, while the other 3 are centered.
Dleslie212
Phoenix
Dustin
5.7L 350
Just future readers - i did ask, and they do not have anything other than the single BIM bracket
Dleslie212
Phoenix
Dustin
5.7L 350
Finally started mine today after having it sitting in a box for almost 2 years.
SquareRoot - what all did you NOT use on your setup because its already fed by the PF4 system?
Coolant temp?
Tach?
Dleslie212
Phoenix
Dustin
5.7L 350
For future readers - water temp and tach both get fed thru the PF4 BMI and outputs directly into the DD gauges so no need to run the extra wiring. Only need to install the oil pressure sender and wiring
Still trying to figure out how to get the GPS BMI to output correctly tho
rchcep_ff
