JW79496
- Mar 20, 2020
- Indiana
- Jared
- K20
I hate to bore most of you with another front leaf spring question. . .I’ve not seen a set of front springs like the ones I have. What brought this about, I was looking to buy front shocks and the stock length extended are roughly 18”. My current eyelet mounts are 17” apart . . . I’ve been scratching my head the past few days on why my front springs aren’t “settling” or lack of better term, laying down. The chassis is a 77 half ton and kept the springs on when I had it blasted and painted years ago. The truck was pulled out of a field when I got it, so no known history. I’d like to believe the springs are original half ton, but with the way they are sitting. . . . maybe they were modified (to add lift) at some point. I have big block and SM465 in the truck. Maybe the third leaf was flipped?
I have a second set of springs, 2nd pic, off a 75 ¾ ton. These would seemingly lay flatter than the springs on the truck. What’s interesting, they are both 3-leaf packs. Half ton springs on the truck are 3.25” wide. The ¾ ton springs on the shelf are 2 7/8” wide.
The truck is sitting about level right now with 1 ton set of springs in the rear. I'm not running a sway bar up front and so would like to have more rake.
