Cummins swap
87silveradok20
Ohio
Levi
Silverado k20
So I'm probably gonna swap a cummins into my truck. I'm wanting to buy entire truck to swap the engine out of. I am going to rebuild the engine before it goes in, so mileage isn't a problem. My question is what generation engine should I go with. Around me early 12v are the cheapest and then 24v and the later 12v are priced about the same. Is there any reason why I shouldnt swap an early 12v and then build it to have more power with the extra money? I guess I really just need some opinions.
marks86
Latham, NY
Mark
12v Cummins
89-93 are the easiest to swap, least amount of wires
94-98.5 are PPump motors and are the strongest ones out there
my vote is for a PPump motor
87silveradok20
Ohio
Levi
Silverado k20
How hard is it to put a ppump on a 89-93.?
87silveradok20
Ohio
Levi
Silverado k20
Also how much HP and torque can I put through a nv4500 and a 14bt ff rear end. Without it breaking constantly.
marks86
Latham, NY
Mark
12v Cummins
for the price it would cost you would be better off just finding a used ppump motor, but there is nothing wrong with 89-93 12v except 89-90 were not intercooled though
the 14b will hold up to ALOT, the stock nv4500 clutch will start to slip after the first group of upgrades(http://www.cumminsforum.com/forum/9...ssion/314312-beginners-thread-read-first.html) and down the road, were talking like 500hp a billet input shaft will be needed
also do some research on 5th gear nut problems
87silveradok20
Ohio
Levi
Silverado k20
So i think I will find a 91-93 to swap only because it's my first cummins swap. And then maybe build the engine a little. Then put a better clutch and fix the 5th gear problem.
marks86
Latham, NY
Mark
12v Cummins
sounds like a good plan to me. let me know if you have any other questions and read though my build thread theres some cool info in there
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
One day... one day the suburban will have a 12v in the engine compartment :lazer:
CSFJ
MadOgre
NA
NA
NA
NA
NA
and a lot slower.....:shrug:
ask me how I know
Ya not even comparable. A 6.2 is the equivelant of a low power 350 with a little extra toque and better fuel mileage. A 6.2 is about 1/4- 1/3 the motor of a 5.9
jimlayhee
