Cruise Control Transducer
Mory Rugg
West Fargo
Mory
I’ve got an 80 K10 and the cruise control transducer is bad. It’s a two terminal Cardone 36-101 part, and I’ve searched the interwebs and have only found some on some sketchy websites. Does anyone have a recommendation on where to purchase one? Thanks in advance!
78C10BigTen
pennsylvannia
C10 BIG TEN
I have been looking for one for my 78 and theyre not cheap just fyi. Ive looked used in ebay and such as well as new at auto stores.
78C10BigTen
pennsylvannia
C10 BIG TEN
Idk if its my transducer or not because i changed the lower speedo cable and gear and spun the in feed on the transducer and the output spun. I spun the cable from the transducer to the gauge and the needle moved but my speedo and cruise still wont work...
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I know, from what I’ve seen they run around $100.
I picked mine up off ebay... $80 and it solved the no cruise control issue. Good luck finding them anywhere else. If you do happen to find one on a salvaged truck, chances are the electronics are wasted from sitting in the elements. 80's technology and moisture don't mix well.
78C10BigTen
pennsylvannia
C10 BIG TEN
Neith
Neither do 70s lol
jlyon1006
