BRetty
- Jul 16, 2020
- Los Angeles
- Franklin
- c10
Today I learned that GMSB is the hottest place on the Internet to discuss PCV valves and vacuum leaks...but I am still puzzled here.
My breather cap on the pass side valve cover had a bunch of pasty, oily sludge up inside it. You can see it oozing out in this pic:
So is this trapped oil and grit from the valves and crankcase? Odd, since air should be flowing the other way. Or is this the oily remains of a sponge/filter element?
Either way, I will clean it out, and get a new breather and PCV valve tomorrow. But if oil has been blowing out through the breather, I have some other problems.
Thanks,
BR
Thanks,
BR
