Affende
- Apr 14, 2014
- ColoRADo
- Affende
- 83 and 84
- C1500 and K3500 3+3
- 250 and 454
Its no secret that push pull steering is .... effective. It is not, however, perfect.
the front end of my truck needs all new steering linkages, the power steering box is sloppy and leaking, and i want to put in a XJ steering shaft ..... i would like to go with a crossover steering setup ... less bump steer, less stress on the parts, etc
My D60 needs new ball joints, and probably new king pins, as well as a good reseal ... so i plan on rebuilding that 100%. while its apart, it would be a great time to upgrade the steering and i will be swapping my front sagging 3 leaf springs for 4 leafs (added a welder and tools, and it has a 454 so i dont *think* i will be too stiff).
Ideally i would like to do this all in one go ... collect the parts, rip it out, and put it all back new.
SO...... can you run crossover steering with no lift (but new slightly higher load springs)??
lifting is a last resort ... dont need it, dont like it, dont want it.
opinions? experiences?
