Thanks I'll give lmc a shot and see what happens
That dwg above was pretty vague. I didn't want to give you bad info, so I checked the master parts list. That wasn't much better - it doesn't even reference any 1986 with RPO NL2 (dual tanks).
Next check was with Inline Tube.
They show different stock numbers for supply/return crossover lines used with 2WD & 4WD.
Supply/return crossover lines for 2WD are stock numbers CTF8105/8106 and for 4WD the stock numbers are CTF8148/8149. I would check with them. The price is the same as LMC's and those Inline Tube guys know a
lot about tubes. That's basically all they do.
