Crossmember differences?
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Is there a difference in the crossmembers for a NP208 and a NP241c? im switching my 208 out with a 241. Just crossed my mind if this was gonna be an issue. My truck is a 1985 K10.
MadOgre
NA
NA
NA
NA
NA
I believe it is the transmission which determines the cross member. My th400/208 uses a completely different cross member than my 700r4/241. Willing to bet the 700r4/208 would be the same as my 700r4/241.
MadOgre
NA
NA
NA
NA
NA
in fact my 86 700r4's adapter is the same one used for my 241.
marks86
Latham, NY
Mark
12v Cummins
1.w cross member
2.half a w cross member
3. flat cross member
4. 1 ton only flat with raises ends
your truck had one of these most are interchange able
MadOgre
NA
NA
NA
NA
NA
Oh so your just swapping transfer cases? If the 241 is a direct swap for your 208 it does not involve the cross member. It just bolts to the back of the adapter. The adapter is what bolts to the cross member.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Correct. Just wasn't sure if the forward driveshaft drop would differ the crossmembers any.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
I have a W crossmember
MadOgre
NA
NA
NA
NA
NA
Ya nope. The 241 and 208 are pretty much identical
Tdabney
