papapavs1
- Apr 13, 2024
- wisconsin
- avery
- c10
I recently purchased a 76 chevy c20 crew cab longbed, 350 with automatic trans. rear driveshaft was out, supposedly for being flat towed many years back. There were two identical driveshafts laying in the back, around 55" each. Well turns out they're completely wrong, way too short and different splines. I counted 32 splines on the front driveshaft, and about 65" of length needed for the rear driveshaft to work. I measured the rear driveshaft on a 78 gmc cab and chassis (longer wheelbase) and it looked to be 65 inches, couldn't see the spline count as it was still on the truck. My question is, Has anybody ever had anything similar before? Will a cab and chassis driveshaft be the same/work? Or else where have you guys gotten your driveshafts for these?
