77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
It has been a few days since I bypassed the externally plumbed water passage under the TBI. I checked it today after the engine had cooled for 10 hours and no coolant has been lost.
Now the weather here this weekend was weird. High temp was only 50 degrees and the low overnight was 40, but the engine still warmed up. I'm at work again tonight and will check it tomorrow again but think I found it.
Now: Why? How does an Edelbrock manifold lose coolant? Why didn't the stop leak crap I put in plug it? The externally plumbed passage under the TBI is to be used for coolant OR to run an exhaust crossover like the old manifolds. Without using this my truck won't run when it is -20 degrees F here in the winter.
I'll need to call Edelbrock and see what they have to say for themselves.
$250 for the Edelbrock 7116 manifold.
$65 for the plastic GM intake manifold gaskets
Many hours for me to install it in the first place.
$400 for another shop to replace the intake manifold gaskets.
$60 for the "new and improved" metal intake manifold gasket.
