77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
8/22/14 I installed the HT383 engine from Chevrolet Performance. About 3 months ago I swapped out the GM intake manifold on it with an Edelbrock RPM manifold as the Edelbrock manifold has a heat crossover tube in it for the cold weather up here. (and it works great!!)
But since the intake swap it has been using coolant. I have to add 300 mL of coolant for every 3-4 times I took the truck out. I used the updated GM intake manifold gaskets which are plastic. When reading about them it is possible for them to crack when installed. Not wanting to mess with the truck I had a shop swap them out to the Fel Pro ones which are similar but metal.
Coolant is still disappearing. The shop that did the work thought my heads might be cracked. They said if it is the heads it will only lose coolant when the engine is cooling down. The cracks will open up as it cools allowing coolant to go into the cylinder. When the heads get hot they expand and the cracks seal up. I verified this last week- I drove to my parents house about 160 miles away and it didn't use any coolant at all.
After realizing how much I've spent on this for a huge headache I went out and added some Bar's cracked head repair stop leak gunk. It has done nothing. It was that or smash the truck head on into the nearest tree I could find...
Yesterday when I calmed down I found that this engine is still under warranty. GM performance engines have a 2 year 50,000 warranty on them. I am one month shy of the 2 year time limit and I've only put 8,000 miles on it.
Now the questions: Will GM deny a warranty claim because I swapped out intake manifolds?
Why did my cast iron vortec heads crack (P/N 12558060). It has never overheated. I use 50/50 mix of antifreeze and distilled water.
IF GM will not warranty it, then what? Put on another set of the same heads and hope they don't crack again? I've been looking at aftermarket ones but hard to find a "truck" head for low end torque.
How did swapping intake manifolds cause it to use coolant?
On Tuesday after I gather up my receipts I'll head into the local Chevy dealer and see what they have to say. In the meantime I'm wanting your guy's opinions.
