TX87R10
- Jun 25, 2020
- Texas
- Txr10
- R10
My square is still on factory everything suspension-wise. I was planning to lift it a little but it is a 2wd and that isn't looking so promising. I've read up on using HD springs and was pricing things out with a local truck shop and just had a few questions -
1. From stock height, how many inches would you estimate the front would be raised with the HD springs? The suspension shop is quoting me it will raise 3" but that seems like a lot.
2. Looking at the picture below you can see the combination of 235 tires and factory suspension make the truck pretty low. Is it reasonable to think that with new shocks and such that the truck will be sitting a few inches higher without updating the springs? Looking it up I think the ride height for the front fender is supposed to be 32" but that seems pretty low (barely higher than the car next to it in the picture)
3. The largest tires they will do after leveling and replacing worn wear parts on the suspension is 32" - I don't see why 33's wouldn't fit but just double-checking that 32" sounds like it should have plenty of clearance.
Truck info 1987 R10 2WD with a 305
Thanks in advance!
Thanks in advance!
