Correct Starter 85 k10
Charlie K
Missouri
Charlie
Hey guys had a starter issue. I have an 85 K10. I bought it from a guy who did some work including a motor swap but I don't trust much after seeing a few things. The starter in the truck was grinding and making a racket. I heavily (5/16) shimmed the starter when I got it to get the clearance right at 1/8" between the starter shaft and the flywheel so I could start it and drive a bit to find other problems. That worked better for a bit but the old starter was abused and needed replaced.
I went to the parts store and they gave me a starter for an 85 350 that was identical to the one I had. Well I knew that wasn't going to work with out an absurd amount of shimming so I questioned the starter. I don't know the year of the motor. Anyway after 30min of looking at parts of other years the 86 starter seemed to look like a better match. He let me take it home and mount it (but not start the truck with it) well if fit way better. Clearances were right on without shims. I bought the part and the truck starts clean without grinding and much faster than before.
My question is do I have an 86 350 block because it worked? I'm not a super mechanic like others on here and this is my first old truck so I'm learning a ton here.
Thanks in advance
Charlie
SirRobyn0
Rob
Charlie, You might try crawling up on top of the engine and look down by the top drivers side of the bellhousing. There maybe a number printed on the engine block there that you might be able to figure out the year of the engine from.
cblackb
