Ellie Niner
- Aug 7, 2021
- Tucson, AZ
- Tory
- K10 Silverado
- LE9 305
My 1986 K10 came to me about 20 years ago with a cargo light, dealer or owner installed with Scotchlok connectors going directly to the dome light. Since the truck is in pretty decent original condition, I want to install the thing correctly, making the holes for switch and lamp housing look factory. I do have a correct switch, harness, and all the other goods needed, but the project has been on hold for long enough that I no longer have any trucks so equipped in the wrecking yards to scope out to refresh my memory. Does anybody have any pictures of the holes in the cab and the plastic trim panel the switch goes into? I do know the proper location for the switch.
Also, is the inner roof panel changed quite a bit between 1983 and 1984, when GM changed the dome light housing from being recessed with a 1004 bulb, to protruding with a 211-2 bulb? I know the earlier setup uses staggered holes and spacers... figured this would be a good time to switch to the better looking (to me) earlier style dome light, as my current one is pretty crispy.
