idrivea2002golf
- Feb 19, 2025
- San Diego
- Spencer
- C20
- Not sure yet.
I have two corporate 14 bolt ff axle as a result of a 4x4 conversion i'm working on. I mention this because they each have different brake lines/routing and I can't seem to find the set I need.
On the RCLB donor chassis, the brake hose between the chassis rail and the axle sits right above the bolts for the diff cover. The left and right lines bend up around the pumpkin and attach right in. Inline Tube shop has these in stock, no problems.
Now the question, where I'm having a hard time. The brake hose between the chassis and diff on my 1981 CCLB truck has nearly the same configuration but the splitter is on an L bracket that about 8" long and points toward the front of the truck. Inline tube does not have these. I can't seem to figure out how to search for this as all my searches return the above as if the 8" arm doesn't exist. What do I need to search to find this?
