BearKing
- Apr 13, 2022
- Black Hills
- Bear
- K10
I have two 1976 Chevy trucks. One is a Step Side Sport and the other is the base model K10 with the 8ft box. Both are 4WD. The long box has a VERY loose front end. You can just put your finger on the U-joint where the stub axle meets the other part of the shaft and move it with your finger up and down. Tons of play. It makes noise when you turn sometimes. I bought the truck from my brother because he thought there was something wrong with it. I paid 400 dollars. It only needed gas…hahaha. It’s a numbers matching truck with the 350 and the SM465/205 sent up. The only thing I found wrong is the problem with the front axle and it won’t lock the front axle when you use the transfer case stick on the floor. Probably a linkage alingment I’m guessing. I want to buy a complete rebuild kit for the Dana 44 front axle. Do you guys know where I can buy one with all the stuff I need and do you guys think I will need buy new axles for the front because they have been wearing metal on metal for a while I bet. Thanks guys for all your help with my trucks, I really appreciate it.
