Got a couple hours in today, was able to pull the clutch, the rest of the front bumper (sawzall to get the rusted bolts off) rear bumper and I’m just four friends away from lifting the bed off. As I’m pulling it apart I guess I’m planning the restoration as I go. Here are some thoughts and please ad your advice as you are willing.
1) Disk brakes on the rear. More on that later...
2)lift kit (coil over or leaf spring)
3) Drive shaft (it has that supporting bearing in the middle, how does that work with a lift?)
4) Plan is to get everything that will get outer color paint off and up to someone who can soda blast it, then prime and paint right away. Well that is underway, have axles, frame over for sandblasting and paint and well that is underway, have the transmission, transfer case inspected and serviced, maybe restored, the engine built (planning on a 383) and then the process of trying to remember what goes where.
