- May 18, 2020
- Auburn, Washington
- Todd
- K20, C10
So’s I come home last night, walking thru the garage that I’d just cleaned the floors in couple days ago. So no errant oil drips; stains etc on the floor. Office a new puddle under ole brown.
Sure nough the aftermarket auxiliary fuel tank circa 1970s is leaking just a tad. Coincidentally I also just filled er plumb full of 22 gal of gas!
Pinhole leak in a weld on the heavy steel tank. No rust, coated in zeibart, just a pinhole re appeared. Found evidence of previous JB weld and yellow crayon marker (probably why it didn’t stick as well…)
Can’t believe this cheap junk these days! Lol
At least it’s in an easily accessible spot and a defect, not rust or something else.
However my real question is….how probable or possible is it that one of those big glass pack mufflers could have a baffle or brace come loose inside it?
Drivers side exhaust has a nasty rattle that is rpm dependent and it’s coming from the muffler. Just one muffler. Everything is fresh, tightened, not hitting anything and re-tightened.
It rattles when you kick it once it’s hot. Not so much when cold.
Seems like it’ll be a tough explanation to the supplier …
