Carb gasket comparison question!
Truck82
Alderton
Christopher
Can anyone tell me if I can use the new gasket that my carb rebuild kit came with? The only difference is that lower inner hole.
I would guess it’s pretty important to have one that’s exactly the same but want to make sure before ordering a different one.
Thank you!
(Everything else in the kit is exactly the same as the old stuff)
75gmck25
Northern Virginia
Bruce
Check to see what passages those holes line up with in the carburetor. If the carburetor plate is solid in those areas, then the gasket is fine. If there are holes that line up, then you need to get the matching gasket.
jbahena95
