Can't get to HL dimmer switch. Ideas?
87ChevyR10
Kansas
NA
NA
NA
Ok, I had the dash all apart to replace bulbs and my HL dimmer switch doesn't work as intended. I have a new one to install. I followed directions in Haynes manual (not very clear) and it seems an air duct is preventing the steering column from dropping far enough to get at the dimmer. Only bolts I found which enabled the lowering of the column are on either side and vertical.
Any suggestions?
Whoever engineered the dash didn't anticipate anything needing fixed. :dancingpoop:
gpmorgan
Tupelo Ms.
greg
You will have to remove the air duct. Don't forget to take the clip off that holds the indicator for the gear selector. Those are the only bolts that hold the column up.
chengny
Yeah, like gpmorgan says - pull the AC crossover duct and release the column mounting bolts. Let the column hang down.
The steering wheel should rest on the front of the seat (if it's all the way forward) and provide support for the column.
Also, before dropping the column, you should disconnect one side of the pulse wiper module and unclip the module from the underside of the column.
Then pull the harness clip from the switch, remove and replace the switch and reconnect.
87ChevyR10
Kansas
NA
NA
NA
Cool, thanks for the tips!
While I'm in the column, what can I do to fix premature turn cancellation? The signals cancel barely off center and most times, I have to either hold the signal level or keep turning it on.
Thx!
The turn signal cam is under the locking plate under the steering wheel. It needs to be clocked in the right position. It has to match the right hole in the locking plate to install and operate correctly.
87ChevyR10
Kansas
NA
NA
NA
Ok, thanks!
Milblazer
Colorado
MilBlazer
Any suggestions?
To drop the column down further you can loosen the two nuts in the engine bay right where the column comes through the firewall. That will aid in letting the column come down a bit more. They are the same size as the nuts that attach under the dash.
78silverado
