Can this be welded, or
Rickf
Grafton NH
1974, 1954 & a 1937
should I use JB Weld? :D
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I'd jb weld it then go test it with a couple good hole shots. Should hold up.
That must of sounded TERRIBLE!
78C10BigTen
pennsylvannia
C10 BIG TEN
How the hell did that happen?
Rickf
Grafton NH
1974, 1954 & a 1937
It's a spicer diff from a polaris ranger w/a diesel, used by a nearby ski slope for hauling guns & hoses up and down the mountain. The gear oil looked like never seize and blew an inspection hole in the case. The pinion nut loosened and walked back into the carrier then locked up the rear end. "It was making a noise from the rear for a while". :banghead:
78C10BigTen
pennsylvannia
C10 BIG TEN
Oh i know all about the "noise". Till its screeching so loud you cant hear over true duals with flowmasters
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
This......
Should probably be in the Rant Thread,...
I can't count the number of things that show up in my shop that clearly spent a lot of time trying to warn the operator that failure was imminent.
But it's always "I dunno. It just stopped."
Makes my hair hurt.
jlyon1006
