chevyk10
- Jan 31, 2014
- WV
- Daniel
- 1984 chevy
- k-10
- 358 Dart block with aluminum heads 430hp/450ft-lb torque
Yep, let's not forget there is a difference in High Volume and High Pressure pumps. Hi Pressure pumps I don't care to use. I will use a High Volume with an oil restrictor to the top end. It's not a bad idea for 6500-8000 rpm small blocks, but if you're not turning that rpm, then no need for it. The oil restrictor to the top end will allow enough oil to the top end but yet won't empty your pan of oil.
Many people will get a deeper pan thinking more oil they won't run out. Well, that's great for helping keep your oil cool and letting any debris fall further from the pick up , but if you don't use an extended pick up tube, the deep pan does not help with that issue.
I do like extra quart pans with windage trays, and a magnetic drain plug in the bottom of the pan to collect any metal particles and not recirculate them into my oil pump and back thru the bearings. But I won't go with a deeper pan if it makes me lose to much ground clearance. It really sucks ripping an oil pan off the bottom of your motor and losing your oil, or knocking the pick up off your pump and you not know it unless your OP gauge alerts you.
I don't run the deeper pan. I run a wider pan. Why would anyone want to use any pan with the improper pickup in it. That would just be stupid. No offense meant.
