Jarrett Melvin
- Oct 17, 2020
- Newfoundland
- Jarrett
- C20
Hi everybody, I'm new here to the forum but I have some questions but first I'll explain my situation.
Currently right now I'm building a truck, basically from the ground up from about 3 different donor trucks. Right now I have rolling K20 chassis, with tank and fuel lines, that's it.
I'm getting ready to put a cab on it. I plan on using a cab off a 1986 1 ton flat bed dually as it only needs some rocker and corner work. Some small dents. It also came with high hump floor, hydraulic clutch pedal assembly aswell as a hydro brake booster. Which is great because I plan on using a sm465 manual trans.
I'm basically just looking for any tips or pointers in taking the cab off and putting it on the k20 chassis. Or even instructions on the easiest way to go about it and what to look out for .
Thanks
Thanks
