Cab Stand or Dolley
TravisB
Travis
I want to build a stand to sit my cab on so I can wheel it around in the garage and get more room to work with the frame. Anyone built something like this or have any ideas what would work? A picture or two would be helpful if you have something.
I work by myself a lot in the garage and moving this cab around alone is impossible so I am hoping to make it easier to do. Bonus points if it considers laying it down so I can work on the floor pans or paint under it.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
My dad built a steel cart on casters that would be good for this. He used it to put a fuselage on, but it could be adapted. These are the only pics I have, but they should give you an idea. If you want to borrow it, you’re more than welcome. The plane went to the scrapper. You’re a bit far, though.
eskimomann209
Modesto
Marcus
I used a furniture dolly and some 4x4s topped with a pallet worked for me
Dmack
Central OR
Dave
I just put some casters on a pallet. Worked well for moving around the shop, but floorpan repair would be a challenge.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I used some 2x4's and casters to build a cart that runs under the cab supports and in the rear to small jackstands (4x4 posts would work too)
Also my engine hoist cab lift, A beam made from construction lumber, basically a wood 'C' channel and uses the bolt hole that the chain normally uses, works pretty good and doesn't mangle anything like a chain might.
TravisB
Travis
Did it not try to fall over? The furniture dolly sounds like a narrow base to work with. My cab still has the glass in it so it's a bit top heavier than a stripped one.
This sounds the simplest and may be what I do.
eskimomann209
Modesto
Marcus
@TravisB it didn’t because the 4x4s laying across it roughly the same length as the pallets
Mine had the Glass in as well
In fact I removed it on that little contraption
TravisB
Travis
Okay I was picturing using the 4bys as stilts. I think I get it now.
sam s
