Cab repair stabilizing
Art Vandelay
New England
Art
Cab is currently on a rotisserie (which is awesome). I will begin the cutting and replacement of floor, rockers and kick panels (one side at a time). Looking for advice on stabilizing cab to keep square. Was thinking of using boat stands with the cab still on rotisserie to keep level or putting back in the frame. What’s the safest way?
When I cut out major sections like rockers etc. I weld angle iron across the inside of the door opening as low as I can and still be able to work.Cut your angle and grind the welds after you are done
And if you are cutting out a lot on either side, like rockers, floor pans and cab supports, it wouldn't hurt to weld in a length of angle iron across the cab to tie both lower a-pillars together.
That's a dam good idea,I never thought of it and never had a problem,but if a person welded angle across both door openings and then welded angle to that across the cab front and back of the door openings,that cab would be stable enough to do anything to.
ali_c20
Austria
Alexander
C20, K5
This is what I made for my K5 body...used thick walled square tubing.
Art Vandelay
New England
Art
Interesting how in a lot of the YouTube videos they don’t brace and cut out both sides.
legopnuematic
Licensed Junk Dealer
MO
Spencer
On my 79, the outer rockers while rusty, were still structurally sound, I cut out the remainder of the floor and inner rockers and kick panels, replaced all that and tied that back together leaving the old rockers in place, after I got the inner structure back and tied in I cut one rocker off at a time and welded the new ones on.
Is it the best way? Probably not, but worked for me.
legopnuematic
MO
Spencer
waterpirate
delaware
v10
5.7 tbi
I saw a tool once that clamped on the striker and bolted to the door hinge holes in the cab. Same outcome, keep it straight.
mattmattmatt
