Cab mounts?
Brownsquare
Wayland, Michigan
Marc
R1500
4.3 V6
Can anyone recommend a good source for complete body bushings for my '87? I've been using LMC exclusively so far but the cab and radiator support kit is always back ordered 10 weeks. I want the oem rubber/steel ones, not polyurethane. I'm getting nervous driving my truck with most of the body washers gone! Don't want to make a sudden turn and have the chassis and box go one way, while the cab and I fly off into the woods!
Doppleganger
OH-MI: Just like it sounds
I got the rubber from LMC - took 4-5 months but they eventually showed. If they are NLA, mine may become available.
Brownsquare
Wayland, Michigan
Marc
R1500
4.3 V6
Thank you! Basically I'm missing 95% of my mounts! Haha. All that remains is the top washer, rubber between the cab and frame, and the bolt. The lower washer that actually holds everything together has rotted away. The lower rubber dropped off about the same time. So about all she's got right now is gravity! I think there might be 1 lower washer left on the whole truck.
Doppleganger
My originals were actually in great shape.....the washers still have alot of the yellow-zinc plating on them. You can have them for shipping if need be.
Ivan_R
