Brush guard
Robin Nowak
CA
Robin
V1500
Good afternoon. I’m new to to this site and do not know if I’m even posting in The right area. If not, I apologize and please direct there.
I have 1990 GMC Suburban V1500. I am looking to put a brush guard on it and I am having a hard time finding one. I can find bull bars but when it comes to full brush guards, the fit guides do not specify this model year.
My question is will a brush guard from C/K 1500’s fit on the frame where they mount? In other words are all suburbans built on the same frame as the trucks? If so, in theory, the guard should fit right?
I realize some C/K body stuff fits and that subject has been beat up to death. But I think this is a frame question.
Any help would be appreciated. I’d post pics but the thing is getting rhino lined (another topic of debate that is out there) and I won’t have it back for a few weeks.
thank you
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
I am 70% sure the front end of the frame is the same. I know the rear is different.
All the brush guards I have seen used the bumper bolts to mount.
http://www.1990suburban.com/brush_guards/index.cfm
Robin Nowak
CA
Robin
V1500
Thank you for responding so quickly. I appreciate it. I was referring to the kind that mounts where the tow hooks are. Similar to these. mid the front measurements are the same then I assume it would work...maybe?
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
I am pretty sure the frames are different between squares and newer stuff. Could be made to work. But I don't believe it will be as easy as bolt on.
Your best bet is to find one used made for a square.
Robin Nowak
CA
Robin
V1500
I just realized there was a link attached. Thanks for that as well.
Robin Nowak
CA
Robin
V1500
Thank you for the response. The search continues. I appreciate the help
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
No problem. I did the same search when I had a 91 Suburban. Came up dry.
I just used an ORD bumper on the 91. Just checked they are no longer listed.
On my 88 now I have an older DIY4X bumper. Call him up, he does alot of custom work, may do a brush guard.
http://diy4x.com/home.php?cat=251
Robin Nowak
CA
Robin
V1500
I appreciate the information. And quick replies and you checking to see if parts are available. You went Above and beyond. I’ll start looking at other options.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
From a cucv probly or SB tow rig.
Robin Nowak
CA
Robin
V1500
Thank you
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Itll take some hunting but every so often you can catch one of the wrecker push bumper/brush guards on craigslist.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Robin Nowak
CA
Robin
V1500
Thank you guys for all the help. I always read these forums but never registered. Glad I finally did.
rlfdavin
