78shortandwide
- Aug 9, 2011
- Denver
- Tom
- C10
no it in the front drive line from the transfer case to the front axle. Its the ball joint in the middle of the constant velocity joint.
Here is a pic of the maintainence kit. It's $19 at RockAuto.com
http://www.rockauto.com/catalog/moreinfo.php?pk=356906
And here is what it's called.
ACDELCO Part # 45U0750 More Information About this Part {#89029390}
SEAT KIT,Prop Shaft JT BALL -; w/4WD; FRONT SHAFT CV AT TRANSFER CASE
this is actually the second one to do this, i think that when my front axle is at full droop the angle is too much for it. I might need to gte a high angle front drive line.
So this is rebuildable them
